Hello, i face the following problem: I have selected turbulence at field calculations in field calculations but i cant see the y+ values at the post processor by applying iso volume. Why cannot i see these y+ values?
Thank you.
Hi @kanastasiou, thanks for posting on the forum
Could you share a URL to your project so that we can take a closer look?
Thank you!
Hi @kanastasiou,
Thanks for the follow-up!
From your simulation run, I see that you’ve not set the Y+ solution field prior to it running:
In order to have it’s value on the post-processor, you’ll need to rerun the simulation considering it.
Hello Igor and thank you for answering. I dont know why it doesn’t show the setting to you, but i am pretty sure that i have set it. Anyways i copied the project, deleted the run and now it runs again but i see again no y+ values.
Hi @kanastasiou,
I’m looking at the simulation settings under your completed “Run 1”. There, the solution field is not set up for retrieving Y+ values.
If you’ve set the solution field after running the simulation, you’ll need to rerun it.
Maybe the problem was that i continued the run instead of starting from the beginning. Now the y+ are visible, thank you!
