Y plus value
I wanted to obtain y+ value but I saw there was an error in the log
can anyone suggest a way to fix this
Hi @sjay,
Your inflation layers show up in the meshing log. What seems to be the issue?
i want to find the y plus value from the control results
Hi @sjay,
Your Y+ can be obtained under the result control I believe. Do take a look there.
i used it but i didnt get any reading for it . please have a look on my simulation
Hi @sjay,
There are results but you need to change the range since it is large, Y+ values for your simulation are in the order of 1e2 to 1e4.
Here is with scale 0 to 1000:
Hope this helps,
Darren
how did you get this ?
how can i change this
Hi @sjay,
you can replicate my view first by hiding all the mesh zones except the surfaces:
By selecting the surfaces under mesh regions (excluding internal mesh and bounding box faces)
then change the field to y+ cell and change the range:
For your later simulation, I used a range of 0 to 100 to visualise.
Hope this helps!
Darren
how can i get the y plus value between 30 and 300
Hi @sjay,
Think this will help:
