If I make filters (under Simulation Runs) and then leave the web page, these filters are not saved.
If I open another Run (and look for instance at its filters, but I am not sure if that is consistent behavior), the filters are saved. So what is the way to save filters in a controlled and predictable way?
<I am using FireFox Version 127.0.2 (64-bit) >
Thanks for your help.
All the best.
Hi @jjansman,
The filters are not browser dependent and are saved in your particular simulation. Here’s a workflow to save the filters on your run:
- Apply the filter of your interest
- Click on another tab on the simulation tree (such as a boundary condition, mesh, materials, etc.)
- The filter will be saved when you open the solution fields
If you jump step (2), your filter will remain unsaved.
Does that help?
Thanks. I had hoped it would be more automatic, and my own workflow was more or less doing something like you propose. I am in some way glad that I know what I do is at this moment ‘the best’.
Thanks for this confirmation.
All the best.
