Hi everyone,
I am trying a proper mesh to do a good CFD for an external flow. I tried dozens of combinations but cannot lower the max non-orthogonality from 88. Also, the boundary layer is not well-formed, and I do not know why. Could anyone help me?
The link to the project:
Hi there,
Thank you for posting on the forum!
We will take a look and get back to you soon
Hi there,
I noticed you do not have an external flow region present for your model.
I would suggest the following steps:
Create an external flow region
Delete the solid bodies
Assign material to the flow region
Create a mesh
Now I have created a mesh with standard default settings, to begin with. The mesh has around 380k nodes. The overall mesh quality is 0.39 which is acceptable. And the non-orthogonality is 0.79
If required, you can then move on to hex-dominant meshing.
I would suggest you to go through these tutorials, if you like
Is it impossible in hex-dominant parametric?
