Unable to select faces in Mesh Creator
Hi i tried creating an inflate boundary layers mesh refinement but i wasn’t able to select the required faces.
Hi @AlfaVictor!
That is probably because you are trying to assign faces to a finished mesh. Make sure to right-click on the Mesh and Delete Results which enables you to define further refinements. Tell me if that helped you!
thank you sir, that did it.
Rgds Aditya
