Hello @stanleychin201 , thanks for using the forum!
By default, the gap detection tool reveals gaps within a tolerance of 1e-5 m. If you slightly decrease this tolerance, you will observe additional gaps appearing near the front and back areas.
Alternatively, within SimScale’s CAD mode, there are several operations at your disposal to address this, including Split, Imprint, Move, Boolean/Unite, Body/Delete, and more. To assist you, an example of the internal flow volume generated is provided here in this link. Kindly review the operations history within the CAD mode.
I hope this is helpful,
Kaan.
hi @kaany, thanks for your reply. the link you provided was not working.
thus , i have refine my model as you said the gap was at front and back areas. so here was the new model. https://www.simscale.com/workbench/modeller?pid=3176911539249415390&geobaseId=35e07a3b-947f-487e-858e-1e050466dc43&sessionId=ac0370a4-198a-4f24-bd14-5bb9918174c0
i hope you can lend you powerful help soon.
Hello again @stanleychin201 ! Apologies, it should be accessible now. Can you check it and see if it helps to unblock you?
@kaany hi.
thanks for helping me for solving the flow volume issues.
i must say…you must be the pro,
thanks alot,
best.
