Hello good afternoon,
Would it be possible for someone to help me in making a CFD simulation on my turbofan?
Unfortunately it’s not working, I don’t know why
I think it’s the boundary conditions but I’m not sure.
Hello Welles, thanks for posting your question on the Forum.
The current configuration only consists of solid parts, and a flow volume is needed to perform such flow simulations.
In case you are only interested in the internal flow through the engine and you have the flow information near the inlet and outlet such as mass flow rate, exit temperature, etc, then you can use the internal flow volume operation. If you are also interested in how the flow is accelerated towards the engine inlet from free-stream, then you can use the external flow volume operation.
With this detailed geometry, computational resources may be pretty high due to mesh size required to capture all details, so I would also recommend simplifying your geometry as much as possible.
