The simulation does not contain at least one pressure boundary condition, which will lead to global continuity errors. Mass balance will be difficult to enforce and the run will likely fail. Please use at least one pressure boundary condition (outlet or i
Following:
Tutorial 2: Incompressible Water Flow Through a Pipe Junction/
trying to start the simulation, but i’m getting
The simulation does not contain at least one pressure boundary condition, which will lead to global continuity errors. Mass balance will be difficult to enforce and the run will likely fail. Please use at least one pressure boundary condition (outlet or inlet).
Hey victorlin,
As the error clearly states, a pressure boundary condition is necessary for continuity to be obeyed. Use a pressure outlet boundary condition for your outlet instead of a velocity outlet as mentioned in this part of the tutorial you are following.
Satvik
