Temperature field started diverging. Please check the mesh quality near the reported location and try refining the mesh. If the problem occured near a boundary, please check the boundary conditions. In case of doubt, please ask for assistance via our support chat. Temperature = 100696 at position: (3.021 m, -5.977 m, 3.286 m).
There doesn’t seem to be a good transition between the boundary layers and the elements in that region, which might be causing a high volume ratio there - leading to the lack of convergence:
That depends a lot on the final cell size. In the documentation for that sort of refinement, you can find the definition of all of those quantities to be inserted, you just have to find one that fits with the cell size after the boundary layer ends.
