I have been running a series of simulations with the exact same settings and minor geometry alterations in the past week. However, for some reason, the last couple have been giving me a “floating mesh” error. Can you please tell me why this is and how I can fix it?
Before I delve deeper into your project, have a look at this post from my colleague Johannes: Most Popular Errors of Simulation - #3 by jprobst - let me know if that helped. Otherwise the PowerUsers and me can jump back in and help you out
I’ve been running some tests meanwhile. This error message is not a common one, first time stumbling upon it.
There was one post with a similar error message in the past, although it was while a simulation was running, and not while the mesh was being generated.
In any case, I noticed that there’s a decent number of mesh faces in error just before the script crashes:
I think Ric has given you about the best answer you will get on this one (That topic of mine was never resolved completely, I did what Ric did (with some effort) for you, find a way around the issue and move on…
Good job Ric!
Tina, if Ric’s answer helps you out enough to continue, you could thank him a little by marking his post as the solution to your problem by ticking that checkmark on his post.
