Thanks! I just set it up like it looks and tried to start a simulation, but got his error:
There are settings defined in the simulation setup which have empty assignments and hence will be ignored for the simulation run. Names of the settings that will be ignored: Subdomain 1
Could that be because I have nothing assigned here, and if so, what do I have to assign?
Hey there, this is a warning, which indicates that you have set an unassigned Subdomain under the initial conditions. You can either delete this, or ignore the warning (I suggest you do the deleting though):
How did you calculate the rotational velocity of your wheels? ( ω =U/r , where U is the linear velocity and r the radius of the wheel)
What did you use as a reference length for your coefficients under the Results Control? (It should be the length of the car across the y-axis)
Please change the direction of your forces according to your orientation cube, Lift is Iz, Drag is dy , Pitch is x (-1 as it is negative x-direction). Have a look here under the Results control.
Finally, It would also help to activate the potential flow initialization.
I calculated it by dividing 20/0,0245, where 20 is the velocity and 0,0245 is the radius of the wheels in meters.
For the Reference Length, I used the length of the vehicle across the y axis which is 0.1765 meters
I changed the force directions, so that’s all good. Do I have to assign anything to the region refinements, and if so, what exactly? In the tutorial its not possible to assign anything so thats why im asking.
