Step-by-Step Tutorial: Homework of Session 4
Recording
Homework submission
Submitting all four homework assignments will qualify you for a free Professional Training (value of 500€) as well as a SimScale Certificate of Completion.
Homework 4 - Deadline: Date, 31st of December, 11:59 pm
Homework Submission Form
Introduction
In this last session, we want to challenge you and see the skills that you have acquired during the course. For this exercise we want you to design your own front wing for Formula SAE, and test it using SimScale by following the same setup and steps in the 2nd session.
Your task is to design your own front wing and combine it with an existing car model that we have used in the previous exercises.
To start this exercise, you first need to have your own CAD software to model the front wing.
You can download the car model without the front wing by proceeding to the next section
CAD Models
Important Note: This tutorial provides you with two different files:
1. Car model without front wing STL
This is a model in STL format which will later be merged with your front wing model. As discussed in the fourth video lecture, we recommend that you prepare a STL master model for your own CFD process with SimScale.
2. Reference Geometry
To make sure that your front wing is in the right position we provide you with a reference model in STEP file format, which you can import to your CAD system. Please make sure to keep the origin of the file.
Reference Geometry
The goal in the end is to create a better design than the existing one by creating more downforce with higher efficiency within the FSAE regulations.
Advice
For a successful simulation we suggest the following things:
  • Make sure that you create a clean geometry This means that you have to make sure that your model is a watertight, closed volume (**no open surfaces or edges). Be sure to avoid intersections and overlapping of surfaces when you create your CAD model.
  • If you have an existing model and you want to test it, first defeature it and remove all of the construction details such as screws, bolts, and logos. (See image below)
To run the simulation on SimScale, it is recommended to use an STL file, that’s why you have to convert your CAD model into an STL model. In some CAD software when you export an STL file, you will lose the identity of the parts and solids, and you will have only one solid for all the parts.
Thus, it is important to follow the following steps to make sure that you will have an STL file with different parts, where you can apply different mesh refinements levels.
Creating your CAD model with different parts
Reference Model: Downloadable version of the Front Wing
STL file export
Exporting a file depends on the CAD software that you are using, but here are the most common approaches to export different STL files for different parts.
Some software keeps the same identity of the parts using colors when you convert the CAD model to STL model, and if you are using this kind of software you will not have any problems. Adjust the tessellation of your surface to high quality tessellation, to give an accurate representation of the curvatures. For STL files, there are two types: STL ASCII and Binary. Choose the STL ASCII format, name your file, and export it.
For other softwares, you have to export a different file for each part.This can be done in two ways:
  1. By selecting the specific part and exporting it as a single part per file. Again, it is important to adjust the tessellation to high quality and the Format to ASCII. Then name the file and export it to a specific folder.
  2. Or you have to hide all the other parts, and keep only the part that you want to export. Export it with the same setup as detailed above.
To illustrate this you can see this example (the following steps can change from one software to another).
  • Choose the Format of your file as STL.
  • Select ASCII format for the STL file.
  • Please make sure that you have built your model using meter units otherwise scale your model to [m], the unit of SimScale is meter [m].
  • Adjust your tessellation to good quality using automatic adjustment or customize it.
  • If you have this function in your software of exporting STL with multi parts, activate it otherwise follow the above steps.
  • Finally name your file and export it.
  • In result you will get a file for every part.
Merging the STL files using a script
Now we have to merge all the STL files (your front wing design and the car body) into one file. To do this we provide you with a script that will do this step automatically for you.
  • First of all create new folder and name it FSAE 4th session optional.
  • Then put all STL (your front wing design and the car body) files inside the folder which you want to merge.
  • Download the script file from here (Script file download)
  • Now put the script inside the folder FSAE 4th session
  • To merge all the STL files in the same file you have to run the script (right click on file Merge_STL, and run with PowerShell).
  • A new window will appear. Click on open.
  • The merging process can take up to 20 min. After this you will have a new file in the folder FSAE 4th session, containing all the parts together in one file.
Using text editor (alternative)
Merging the STL files can be done using another option by editing the STL file itself, to do this you need a text editor. If the script option does not work for you, we suggest this option as an alternative
As you know from the last session, the STL file will start with solid name and finish by endsolid name.
All that you have to do is open a new text file, and open the other STL files using your text editor and copy paste all of the information from the STL files into the new text file.
To do this follow the next steps:
  • Right click on the first STL file and choose Edit with (your text editor)
  • A new window will open with the text editor.
  • Click on the first line solid name, scroll down to the end of the text, press Shift and click on the last line in the text, ( make sure that you select all the text).
  • Copy the file Ctrl+C and paste it in the the empty text file that you have created using Ctrl+V.
  • Repeat the same steps with the other STL files, but this time you have to paste the STL text after the end of the previous text in the new text file
  • Do the same steps with all the files of your front wing and car model. You will end up with one file containing all of the car parts.
As soon as you finish this step, save the file with the name of the file, but make sure that you add the extension .STL
Creating the project in SimScale
Now that we have the full model with your front wing design and the car body, it’s time to move to the next step, Uploading the new STL to the platform.
To do this go to www.simscale.com login into your account by clicking on LOGIN on the top right corner, and enter your login information.
Then in the Dashboard click on New project in the top right corner.
A new window will appear. Fill the information in with the title of the project, description of the project, category of your project, and you can Drag and drop your CAD files, or select the file from the folder, (select the last file where you have merged all the STL files together).
When you finish click on Create new project, you can proceed with the mesh generation and simulation setup steps describes in the exercise from session 2.
CATIA V5 (I am using this CAD system) does not want to export as STL, it can only export as IGES, STEP and so forth. So how can I fix that? Is anyone using CATIA V5
My ASCII Stuff looks different bc of CATIA I have no idea what to do with this stuff now bc the Powershell Script does not work at all.
It looks like this and not how it should :sweat:
can anyone help me?
it does not get the geometry correctly. Can anyone assist please. It is not working out with CATIA STL Files and I don’t want to remodel all over in Onshape I btw. do not know how to use.
Thank you.
Hi @estephan,
does CATIA V5 not have an option like STL Rapid Prototyping where you you can export your file with less size and a more structured mesh? Maybe this may help you. In the meantime I will see how you can use PowerShell for CATIA :slight_smile:
I did this but it does not work. The outcome is the picture I posted. Just senseless points
Hello @estephan,
You don’t have to remodel it in onshape. Just upload the step file to onshape and export it as STL ( as shown in the first post).
Richard
but then it is no assembly. I cannot do seperate parts then. I can only export from CATIA the whole product otherwise all constraints are gone.
Hello @estephan can you share your STP or IGES file with me?
it worked now but my geometry is only half there (car) and the front wing is too far down even though I used the reference model you inserted in the homework description…
can someone fix that?
@jousefm @Akrem
CATIA I can bring the frontwing up but later it is back down. I guess the reference model is incorrect because if I input this one too, it is also down in z-direction
@estephan did you fix it with my instructions? Or how did you do it?
I saved the CAD-file as STEP and imported it in Onshape and exported as STL, but regardless of CATIA or Onshape. The reference model you uploaded is to far down in z-direction and does not match the S4 car model. Please do recheck your reference model. I can just switch places in CATIA product assembly workbench but not in the part itself and I need to export the parts as STEP and I am really sick of it right now.
Please recheck the reference model. I spent about 10 hours on this now and it still is wrong in the global system. I will leave for vacation this night and I wanted to finish this because I will not return until the 9th january. And this really stinks.
Proof for that see picture of my steps I opened in CATIA V5
Can someone open my project and look at it? Thank you
hey @estephan yes that’s right, I see the model have to be translated 0.592m in the Z direction I’m gonna update the STL file, you can donload it in some min.
One thing now you, have the modify the dimensions of the domain box and refinement boxs by 0.592m in the Z direction.
I havent set up my mesh yet. Shall I create a new project with the new STL file? and for the new STL the bounding box has to be moved upward. Did I get that right?
Does it matter that I have both halfs of the frontwing, not only the half or do I have to redo that as well?
Thank you
@estephan you can download the model in the right position now.
You got a link for me?
Thank you very much for your support! :slight_smile:
You are welcome, i have updated the link in the tutorial you can download the model for the tutorial “Car model without front wing”.
