Recording
Homework Submission
Submitting all four homework assignments will qualify you for a free Professional Training (value of 500€) as well as a SimScale Certificate of Completion.
Homework 3 - Deadline: Date, 22nd of December, 11:59 pm
[Homework Submission Form] (Simulation Software | Engineering in the Cloud | SimScale)
Introduction
In this exercise we will investigate the effects of side wind on the performance of the car. Your task is to investigate the full car model Model-Conf-Yaw. The velocity of the car will be considered constant at 20 m/s with side wind.
To start this exercise, please import the project into your workspace by clicking on the link below:
Mesh Generation
In the Mesh Creator tab, click on the geometry Model-Conf-Yaw
Click on the New Mesh button
A new mesh operation will be generated automatically. Next change:
Type to Hex-dominant parametric (only CFD)
Bounding Box geometry primitive to the following:
Number of cells in x direction to 105
Number of cells in y direction to 60
Number of cells in z direction to 30 -
Number of parallel computing cores to 32 [Scroll down to change other values to optimize the meshing parameters]
Cell limit for refinement termination to 10
Buffer cell count between refinement levels and Minimum angle for feature detection [°] to 2 and 45 respectively
Mesh-to-geometry conformation iterations to 6 and Max iterations for mesh conformation to 1
Detect features between levels to false
Max smoothing iterations for surface normals [-] to 1
Max face aspect ratio for layers [-] and Max ratio of layer thickness to medial length [-] to 0.55 and 0.35 respectively
Max overall iterations for layer addition to 3
Max non-orthogonality angle to 75
Min cosine for face twist, Min normalized cell determinant,Min face weight and Min volume ratio between neighbouring cells to 0.005, 0.005, 0.01 and 0.0075 respectively
Relaxed max non-orthogonality angle to 80
Click Save to register changes.
Background Mesh Box
Next go to the Background Mesh Box item and change the mesh box dimensions to the values shown in figure below. Click Save to save the changes.
Material Point
Go to the MaterialPoint item and change the values to those shown in the figure below. Click Save to save the changes.
Cartesian Box-lower
Next go back to Geometry Primitives and click on +New and then Cartesian Box to define a new Cartesian box that will be used to define mesh refinement area.
After creating a new cartesian box, you will be directed to the definition of this cartesian box. Rename it to Cartesian Box-lower (optional) and change the dimensions to those shown in the figure below. Click Save to register your changes.
Cartesian Box-upper
Follow the same procedure to create a second cartesian box geometry primitive. Rename it to Cartesian Box-upper (optional). This time change the dimensions to those shown in the figure below. Click Save to register your changes.
Now we will start creating the mesh refinements. For this proceed to Mesh Refinements and click +New
Mesh Refinement 1
A new mesh refinement will be created. Rename it to Surf-body-diff-Wsides-Radsup (optional).
Change the Type to Surface refinement
Set Level min and Level max to 5 and 5 respectively.
Change Filter for entity types to faces and select body, FWEPin, FWEPout, RWEP, Diffuser, Radsupport and Driver. Click Select assignment in order to see the selected assignments highlighted in the viewer.
Mesh Refinement 2
Follow the same procedure and create a new mesh refinement named Surf-wings-wheels-susp-bars (optional).
Set Level min and Level max to 6 and 6 respectively.
Change Filter for entity types to faces and select FWmainwing, FWflap, RWflapa, RWflapb, RWflapc, RWflapd, Frontsusp, Rearsusp, Barre, Reartire and Fronttire. Click Select assignment in order to see the selected assignment highlighted in the viewer.
Mesh Refinement 3
Create a new mesh refinement named WheelHub-cp (optional).
Set Level min and Level max to 7 and 8 respectively.
Change Filter for entity types to faces and select Frontur, Rearur, ReartireCP and Fronttirecp. Click Select assignment in order to see the selected assignment highlighted in the viewer.
Mesh Refinement 4
Create a new mesh refinement named Sidepod (optional).
Change Filter for entity types to faces and select Sidepod. Click Select assignment in order to see the selected assignment highlighted in the viewer.
Mesh Refinement 5
Create a new mesh refinement named Radiator-PorousZone (optional).
Set Create cellZone to true and rename cellZone name to RadiatorZone.
Change Filter for entity types to faces and select Radiator. Click Select assignment in order to see the selected assignment highlighted in the viewer.
Mesh Refinement 6
In order to create a separate feature refinement for small features, create a new mesh refinement named Feat (optional).
Change the Type to Feature refinement
Then click the + button to add an extra value. In the first row, change Distance and Level value to 0.0015 and 8 respectively. Similarly, change the value to 0.005 and 6 in second row.
Mesh Refinement 7
To define the refinement level for the created cartesian box geometry primitives, create a new refinement and rename it to Region (optional).
Change the Type to Region refinement and set the level to 2
Select Cartesian Box-inner and Cartesian Box-outer under Assigned Geometry Primitives
Click Save to register the refinements for the specific cartesian boxes.
Mesh Refinement 8
Next we will define layers over the car surfaces in order to capture the results more accurately within the areas we are interested in.
Create a new refinement and rename it to Layer-Car (optional).
Change the Type to Inflate boundary layer
Then change Number of layers [-], expansionRatio [-], finalLayerThickness [-] and minThickness [-] to 3 , 1.05, 0.45 and 0.001 respectively.
Select all the faces except Radiator, Radsupport, MRF_F and MRF_R under Surfaces with layers and click Select assignment in order to review the selected surfaces in the viewer.
Mesh Refinement 9
For the floor layers, create a new refinement named Floor-layer (optional).
Change the Type to Boundary box layer addition.
Change Bounding box face to Zmin and then the Number of layers and MinThickness to 3 and 0.001 respectively.
Mesh Refinement 10
Create a new refinement for the front MRF zone named MRF-Wheel-front (optional).
Change Type to Surface refinement
Set Level min and Level max to 7 respectively.
Change Create cellZone to true and rename cellZone name to FrontWheelZone.
Change Filter for entity types to faces and select MRF_F
Mesh Refinement 11
Similarly, for rear MRF zone create a new refinement named MRF-Wheel-Rear (optional).
Set both Level min and Level max to 7 respectively.
Change Create cellZone to true and rename cellZone name to RearWheelZone.
Change Filter for entity types to faces and select MRF_R.
Once you have defined all 11 of the mesh refinements, go back to the Operation 1 and click Start.
Due to the fineness of the mesh, the meshing operation can take 100 to 140 minutes to finish.
Simulation
Once the meshing operation is complete, go to the Simulation Designer
Click New Simulation and name it Conf-Yaw (optional; you can choose any name you want). Then click Create.
Analysis type
Under Analysis Type, switch to Fluid dynamics and then select Incompressible. You don’t have to change any other properties here.
Click Save
Once you save the analysis type, the items in the Navigator will expand. All of the red entities must be set up in order to perform a successful simulation run.
Domain
Proceed to the Domain item in the Navigator and select the mesh you just created. Then click Save. You will see the loaded mesh of the selected domain in the viewer. For the easier mesh handling, it is recommended to switch to the surfaces render mode in the top viewer bar.
Material
Next we have to define the fluid material. Go to Materials and click on +New
Click on Import from material library to import the desired material from the material database.
Select Air and click Save to import this material directly from the library.
Select region0, RadiatorZone,** Zone, and Zone_1 under Topological Mapping
Then click Save
Initial Conditions
We will now proceed to change the initial conditions. Go to k and change the Turbulent kinetic energy value [m²/s²] value to 0.06 and click Save.
Next go to Omega and change Specific turbulence dissipation rate [1/s] to 44.7 and click Save.
Boundary Conditions
Now we will proceed to the most crucial and important section of the simulation setup. We will define one by one the inlet boundary condition, and it will be different this time, because we want to investigate the side wind effect so we will customize the inlet boundary condition to control the angle of the free stream according to the car. We will then define the boundary condition for the sides, and next we will proceed to define the conditions for floor the roof and car, you have noticed that we don’t have symmetry plan like in the previous session because we are working with the full car.
Go to Boundary Conditions and click New in order to create a new boundary condition.
Inlet
Name the newly created boundary condition to Inlet (optional).
Set the Type to Custom
Under details select inlet outlet for velocity
Then under details inlet valve > properties we will specify the X and Y components of the velocity vector depending on the freestream angle of 20°,
We calculate the velocity components with the help of trigonometric ratios formulas calculate the X component with Cos ratio and Y component with Sin ration (check the picture below), for 20° X value =18.79 [m/s] and Y value = 6.84 [m/s]
For Pressure select Fixed value and under Details > Details for pressure keep the value of 0[m²/s²]
For (K) Turbulent kinetic energy value [m²/s²] value and (Omega) Specific turbulence dissipation rate [1/s] respectively under details enter 0.06 and 44.7.
Assign the Topological Mapping to boundingBox1, boundingBox2, boundingBox3, boundingBox4 and click Select assignment in order to see the selected assignment in viewer.
Click Save
The formula to calculate Uy:
The formula to calculate Ux:
Roof
Create a new boundary condition named Roof (optional).
Change the Type to Wall and under details select Slip
Assign the boundary condition to boundingBox6 under Topological Mapping
Click Save
Floor
We will now define a moving floor boundary condition. Create a new boundary condition named Floor (optional).
Change the Type to Wall and under details set Velocity to Moving wall velocity. Because we are investigating side wind we have to enter the same vector components of the inlet velocity: x value [m/s] to 18.79and y value [m/s] to 6.84
Select boundingBox5 under Topological Mapping and click Select assignment in order to see the selected assignment in viewer. Click Save to define the floor boundary condition.
Car
Create a new boundary condition named Car (optional).
Change the Type to Wall and select all the entities starting with solid_0 except for solid_0_Reartire, solid_0_Fronttire
Click Save to define the boundary condition for the car.
Front Wheel
Next we will add a rotating boundary condition for the wheels. Create a new boundary condition named Front wheel (optional).
Change Type to Wall and Velocity to Rotating wall velocity. Then change:
Origin x value [m], y value [m] and z value [m] value to -0.41566, 0.670378 and 0.219731 respectively.
Axis of rotation x value [m] and y value [m] to 0 and 1 respectively.
Angular velocity [rad/s] to -90.9
Then select solid_0_Fronttire under Topological Mapping and click Select assignment in order to see the selected item in the viewer.
Rear Wheel
Create a new boundary condition named Rear wheel (optional). Change Type to Wall and Velocity to Rotating wall velocity. Then change:
Origin x value [m], y value [m] and z value [m] value to 1.13634, 0.670378 and 0.219731 respectively.
Then select solid_0_Reartire under Topological Mapping
MRF zones
Add a Rotating Zones under Advanced Concepts named Front wheel MRF. Then change:
Then select FrontWheelZone under Topological Mapping
Similarly, perform the same procedure and create a new Rotating Zone. Rename it to Rear wheel MRF. Then change:
Rotation center x value [m], y value [m] and z value [m] value to 1.13634, 0.670378 and 0.219731 respectively.
Rotation axis y value [m] to 1
Angular velocity [rad/s] to -90.91
Then select RearWheelZone under MRF zones and click Select assignment in order to see the selected item in the viewer.
Porous Media
In this section we will define the radiator volume source via porous media. Expand the Advanced Concepts tree item and proceed to Porous Media. Click +New to create a new porous media definition.
After creating a new porous media definition, you will be automatically directed to the properties panel. Change:
Name to Radiator-PorousMedium (optional).
Coefficient d x, y and z values to 18463.81, 1846381.09 and 1846381.09 respectively.
Coefficient f x, y and z values to 1.09, 108.97 and 108.97 respectively.
Coordinate system e1 x, y and z values to 0.93, 0.15 and 0.34 respectively.
Coordinate system e3 x, y and z values to -0.34, -0.054 and 0.94 respectively.
Scroll down and select RadiatorZone under Topological Mapping.
Click Select assignment to see the selected volume source in viewer.
Numerics
After defining all the boundary conditions, we will proceed to set up the numerics for our simulation. Go to Numerics and change:
Relaxation factor for field p, Relaxation factor for equation U, Relaxation factor for equation k and Relaxation factor for equation omega to 0.2, 0.5, 0.5 and 0.5 respectively.
Furthermore, under [p] pressure solver, change Absolute tolerance, Relative tolerance and Number of pre-sweeps to 1e-8, 0.01 and 1 respectively.
Scroll down until [U] velocity solver and change:
[U] velocity solver to Smooth solver, Smoother to symGaussSeidel and Absolute tolerance to 1e-7. Do the same for [k] Turbulent kinetic energy solver and [omega] Specific turbulence dissipation solver
BothGradient scheme for default and Gradient scheme for grad(p) to cellLimited Gauss linear
Scroll down to the end and change:
Laplacian scheme for default, Laplacian scheme for laplacian(nu,U), Laplacian scheme for laplacian(nuEff,U) and Laplacian scheme for laplacian((1|A(U)),p) to Gauss linear limited corrected
Click Save to register all of your changes.
For for more steps, please go to the following forum post: [Step-by-Step Tutorial: Homework of Session 3 section 2 - Further Setups and Post-processing]
(Step-by-Step Tutorial: Homework of Session 3 section 2)
