Is it possible to use the ‘statistic’ tool in the post-process phase to determine the average of a variable within a restricted volume?
for example, is it possible to see the average of a value only in the low volume? (see image)
Hi @s289286,
Unfortunately there shouldn’t be a way to do that if you’re trying to do it on a single body. Even if you split it in two with a cutting plane of some sort on the post processor, the quantities will still be taken from the whole model.
Maybe a 3rd party post processor such as ParaView might be able to help you with that though!
