I have this Standard Algorithm mesh that grew enormously, what have I done to make it so big?
The 2 refinements I used are the same as I used for my Hex Dominant Parametric meshes which stayed around 15 million cells.
I stopped it at over 80 million cells. Here is the log:
SimScale incorporates Simulation Modeling Suite™ software by Simmetrix Inc. © 1997-2024. All Rights Reserved.
Model import took 20.958646361s.
Maximum precision of model and its entities: 0.001031866166658002 m.
Absolute small feature tolerance: 0.001 m.
Layer refinement was not applied on 8 faces because they were removed by small feature suppression, by the non-manifold boolean for conformal meshing or assigned as start/end faces in a sweep mesh refimenent.
Number of faces after 5m0.046066471s: 986977
Number of faces after 10m0.020021496s: 3740308
Number of faces after 15m0.009116597s: 4715356
Number of faces after 20m0.031016382s: 4715356
Number of faces after 25m0.000201957s: 4715356
Number of faces after 30m0.000317487s: 4715356
Number of faces after 35m0.004106731s: 1674168
Number of faces after 40m0.004760424s: 4232347
Number of faces after 45m0.099892596s: 4743954
Surface meshing took 49m41.95172042s.
Number of cells after 1h14m32.927909123s: 13525231
The mesh may be finer than desired. Please check the model and the mesh settings
Number of cells after 1h39m23.90492571s: 81189113
