Solution field result in Excel file
Hello Simscale Team,
I want to extract data from solution fieldin excel form or in CSV file. please help me with this.
Thank you in advance and regards,
Pooja Ingle
On any results graph in the various simulations’ plots, there is a hamburger type dropdown in the top right that lets you download a csv file of that plots data (then, in Ecxel you are on your own :wink: ).
Any update?
In addition to Dale’s suggestion; in case what you’re looking for is exporting the solution field to a csv file (coordinates of nodes vs solution variables, etc), then this can be done by using a third party software such as Paraview. You can download the solution field in the post-processor and import it to Paraview to carry on. More information can be found here and in Paraview forums.
I hope this helps,
Kaan
