I have a steel plate like this
![image|467x500](upload://6730RlPbkRZhVQtoEnMc3bdh2aN.png
It uses fixed support with 4 holes in the top part.
And load force on the bottom part.
But there is a wall on the right (purple color), how to represent it as a boundary condition?
I tried to use primitive geometry, but it is ignored.
Fixed value is almost the right thing, but it constrain it always in both directions in selected axis, I need just one way.
I watched a ofiicial video about boundary conditions and read the documentation, but it is very hard to understand, there would really help some self-explaining real live scenario image.
Hi there,
If you have a private project, you can share with support and let us know the name of the project.
If it is public project, you can copy paste the project website link here.
Sorry for the delay in our response. I just took a look at this project and you seemed to have run all simulations successfully. Did you manage to find the solution to your problem?
It looks like you modeled a part of the desk and assigned it fixed support. That seems to be a nice solution. That makes absolute sense for the problem you are trying to solve. I would have recommended you to maybe assign just the longer surface as fixed support rather than one at the top and one at the bottom because that is the direction you wanted to block any movement in and you would also have got more real stress values on the desk as an additional result, but I think it should have the similar effect in terms of simulation of the holder since that is your main subject.
If you still have any issues with this project, do let us know and we will get back to you here.
