Simulation Failed
The following simulation run(s) failed:
  • Run 1
    • Two of the points defining the pin connector Pin connector 1 are not in the same line of the axis direction (coordinates of point 1: [-2.477e-18, -3.750e-02, 1.388e-17], coordinates of point 2: [-8.783e-02, -5.250e-02, -7.286e-17], axis direction: [0.000e+00, 1.000e+00, 0.000e+00]). Please make sure that the assigned surfaces have coaxial axes of rotation, this will guarantee that the points are in the same line defined by the axis direction.
Hi @s2318236, thanks for posting on the forum and welcome to the SimScale Community :handshake:
When stablishing pin connector relationships, the faces which receive the assignment need to be concentric otherwise the simulation will result in an error as explained in the connectors documentation.
Try and make the faces concentric and keep us posted of the results!
