I trying trying to simulate (Nageli henge measuremenets by jjansman | SimScale , simulation “Kort, =17.5, z0=0.01m, Fineness=7.5”) a fence (as used in an article, Nageli, 1953: Nägeli, Werner, Untersuchungen über die Windverhältnisse im Bereich von Schilfrohrwänden, Mitt. Schweiz. Anst. Forstl. Versuchw., 29, 213–266, 1953 ).
The fence (at y=0) is a box ( 25m wide, 2.2m height, 40cm thick) which I gave a perforated plate. The ABL wind comes from negative y to positive.
In Porosity & Porous Media | Advanced Concepts | SimScale I read for ‘Direction’:
Flow direction: With this input, the user can specify the principal flow direction within the medium. This direction is based on global coordinates.
So I expected that I have to give ‘Direction’ (x,y,z) of the perforated plate as (0,1,0) as that is the general wind direction. If I do that the wind behind the fence is almost independent of the ‘Free area Ratio’. See Runs ‘ap-12-010’ <[aerodynamic porosity]-[value]-[xyz]> and ‘ap-8.5-010’. Also the results are quite different from the experimental data of Nageli.
If I use (x,y,z) as (1,1,0) ‘Direction’ in perforated plate; the simulation (Run: ‘‘ap-8.5-110’’) is very close to the experiment data of Nageli.
It looks I don’t understand the meaning of ‘Direction’ in perforated plate. Can you help me?
All the best.
P.S. For ‘Free area Ratio’=0.085, different Direction configuration (000,001,010,011,100,101,110,111) are evaluated, see that Simulation “Kort, =17.5, z0=0.01m, Fineness=7.5”
