i’m using the drone arm sample. Changing the load from 10N -> 1000N will definitely destroy the part. The displacement will go up to 0.15m. Is there a filter/solution field that shows the overload of the part. e.g. red = structure will break.
The graphics for stress fields only show the stress relatively. e.g. red = max. stress
Rescaled to a yield stress of 40MPa (red = broken)
You could also use a calculator filter to compute directly the factor of safety (yield stress/ von Mises stress). For values below 1 the part would “break”:
Thank you very much @rszoeke, I didn’t understand at once that variable name can contain spaces.
Is there a way to control opacity with this filter? I suspect some stressed points to be inside the joint, not visible on the surface, I’d like to hide under-critical surface.
