hello, I’ve run a lot of CHT simulations including sufficient steady state/transient analysis and run time, the case is to see the cooling effect and see the temperature of the gears fed by the oil fluid, but I still doubt the results/
can you help me to check the simulation result is correct, and whether my geometry has problem too?
operating conditions:
- SAE 30 fluid oil temperature 20 degrees C
- gear temperature at 70 degrees C
simulation run project ‘’ V:oil 4.2 m/s wall & run 51 ‘’
I really appreciate any help, thank you
This link project simulations:
