I am struggling to understand how to apply loads to a hole in a plate which is part of an assembly. This will be a force in a prescribed direction not pressure. I tried placing a bolt in the hole and applying force to that but SimScale complained that some (?) parts were not connected. Do I need to Boolean-join all the parts in the model assembly so they act as a monolithic block?
Hi @bildan,
if you are seeing only pressure as available load options, you are probably using the “static analysis” and not “static analysis - advanced” analysis type - its there for historical reasons and will be removed soon. Changing to the “advanced” solver will make many new load types available. See this post for further information.
Regarding the problem with not connected parts: If you have a multi-part assembly you have to connect those parts using Contacts or Physical Contacts such that they can transfer forces between each other. You do not need to fuse multiple parts, but it is a good practice to get a first simple version of the analysis going and then gradually reaplce those fused parts with more physically correct connections, if needed. For more information releated to the different contact models you can have a look at our documentation:
- SimScale Documentation | Online Simulation Software | SimScale
Richard
Richard
