Screw simulation
Hi!
Is there any tool that can represent bolted joints ? Or is there some method to represent them without problems?
Thanks!
Hi @MaikelLamb!
A similar topic has been discussed not too long ago: Bolt Simulation - although there is a difference between a screw and a bolt the approach can be adapted or even be the same.
You can already share your geometry/project link with us to have a look at it and make some suggestions.
Thank you @jousefm !
I will use this information and if doubts arise, I will not hesitate to ask you.
