Copy of static 3>run 8 & 9 ( results not saved explained below)
Structure is compressed and reaction forces at the fixed bottom support are calculated using the Area Calculation>Sum.
The solution fields and calculations are saved can be accessed for runs before the run 8 and 9 in Copy of static 3. However they are not visible in run 8 or 9. Convergence chart shows convergence till 14 s out of 35 s but no results option is there in the simulation tree.
Hi there, thank you for using the forum!
Indeed, the results do not seem to be recovered, I will report this to the team and get back to you as soon as I have news.
Hey
In the same simulation ( copy of static 3) , I have ran the same simulations again. Namely run 11 and 12. The results failed to get saved again. Please help.
