Questions about the tutorial
Tutorial: Learning about Aerodynamics Simulation of Flow Around a Vehicle. In this process, I want to create a separate volume within the outer volume created in CAD mode, so that if the outer air velocity is 20 m/s, a part of the interior is 10 m/s. What should I do?
Hi @jeehwang1234,
Thanks for posting your question, and sorry for the delay.
The first thing to do is to adapt the CAD model for that situation, I mean, you must have a place inside the vehicle that the air will pass through and it must be draw in a native CAD software, as for this particular model there is no path for that inside the car.
After adapting the geometry in a CAD software, I recommend you to take a look at this page for more informations on how to perform a volume extraction:
best,
