Propeller cavitation analysis
can we analyze propeller cavitation in incompressible type simulation?
Yes, you can analyze propeller cavitation using Incompressible analysis. However knowing the details of the simulation would help answer this with certainty.
Cavitation properties of the fluid, are characterized by setting the bulk modulus (or fluid elasticity), the saturation pressure, and its molecular weight, all defined in the materials library. The local flow characteristics, along with these material properties, determine the extent of the cavitation within the flow domain.
We have this webinar on Cavitation Analysis on SimScale which might be helpful for you
