Project about grag and downforce
Hi, I am doing a project about aerodynamics and I have to test a simple wing from a formula car. My question is, I have been trying to simulate both forces but I have been unable to do them because I haven,t figured out how to make them. Also I’ve been watching some tutorials but there aren’t many of them explaining this topics.
Hi @4071030, thanks for posting on the forum :slight_smile:
Welcome to the SimScale Community :handshake:
Have you checked out how to set up Forces and moments plots, as per here? The results will make it possible to obtain both lift and drag for your vehicle.
Tell me if that helps!
Thanks, it has worked perfectly, but in what units is the data voiced in the case of the drag and downforce (Y axis).
Hi @4071030,
It’s usually displayed in Newton. However I guess that depends on the unit system you’ve chosen for your project. Could you share its URL for us to take a closer look?
The project I was looking at as example was this :
(SimScale Login)
But as I said before the units are not specified
Hi @4071030,
To me, it appears as Newton:
Are you able to see this?
Thanks for the photo, that part of the text didn’t appeared.
You’re welcome :slight_smile:
