I am PERRINN official member. I run simulation which was stopped due to exceeding the maximal runtime. When I try to see the results (it run for over 2000 time steps and the results were saved every 250 time steps) I get an PE_008 error.
Our other member stopped his simulation manually and have a similar problem. The only difference is that he gets a PE_013 error.
Now I have the same problem with the simulation that finished correctly. According to simulation log it came to the end but I cannot view or download the results. I get the PE_008 error.
Hi @akosior,
thanks for reporting! It seems like there was a problem sending the result to the post-processor who was then unable to open the data and reported the error. I forwarded your report in order to investigate this suspicion. @bdaqui please keep us posted.
Sorry for the inconvenience
Hannes
Hi @akosior
Thanks for your feedback! I believe there are two issues at play here:
Simulation 1 - Run 1. I can open the result right now. Considering the error triggered (PE_013) and what from what I can gather, I reckon the result was not ready yet for post-processing. After waiting a while, it would be available. Please do let us know if this is still not working for you.
On the second case, I can confirm what @jprobst said above. There was indeed a problem while sending the result to the online post-processor. We are investigating
Please do not hesitate to write again, if you encounter further issues.
thanks for the info. I did not have any problems with Run 1 as it was run on a 3M mesh. At the moment I think that there is some problem with large data set that you are having. I had a problem with simulation on 11M grid with results saved every 250 time steps (6 saved times) but there was no problem while I saved only last time step.
