Hi, I’m running some CFD simulations on a simple case study for an university course and I’m having trouble using SimScale post-processor.
The problem I’m facing is that either the countours change after a while (see attached screenshots) or it doesn’t even work from the beginning, showing an almost homogeneous contour plot equal for all the variables (as in screenshot 2). I know other course mates are having the same problem.
Reloading results doesn’t help at all and it is not a simulation problem as I can correctly view the results in ParaView.
I’d use ParaView, but I like most SimScale post-processor also because it displays unit of measures, which ParaView apparently doesn’t (does it really?), so could you please help me?
Thanks for reporting this - will forward this to my colleagues from the engineering team and we will get back to you as soon as possible. Sorry for the lost productivity!
Hi @nfranzoi: Please disregard ‘Time 0’, as it means simulation did not run yet. For pressure graphs you need to scale better, I think, but you should expect low pressure where you have high velocity: without project it is not obvious to diagnose from your pictures.
Shame on me! The time must have rewound without me noticing and the other times the post-processor opened the result at the initial time rather than at the final (I’m running steady state simulation so I guess time refers to the iteration step, am I wrong?). By clicking on the last frame button on the post-processor everything got fixed.
Thank you so much, also for the hint on pressure graph scale.
I guess this closes the ticket, so there is no need to contact the engineering team @jousefm .
Thank you to everybody for your kind support.
