Post-processing animation
Why is my animation in post-processing only 3 frames?
Project:
Hi ksalazar,
I see you did 1000s ,but I see in this doc you need to adjust this setting (red line), possibly there is the default of 300 being used & 3 frames.
And this document seems more detailed. Hope it goes Ok :slight_smile:
I created a particle trace and picked a position but the animation just gets stuck at 0. What am I doing wrong? Also it seems I can download the post-process results, is there a way I can use the downloaded results to create an animation?
Hi ksalazar,
Ok, here are my settings with the model, not brilliant, but I was able to get the animations to work. I just kept varying the animation parameters, particle trace, model background colour & velocity range.
Here are some screenshots of my parameters. I’m sure there are some sweeter settings, but its pretty interesting to see the animation flows.
I think you can create a video file as well but I didn’t make a copy, but you should be able to do this using this button.
Thanks for the challenge & learning experience, it was interesting :slight_smile:
Final animation view
Parts Colour
Cutting plane (as previously setup)
Particle trace settings
Animation settings
Thanks for the settings! It was really helpful!
Glad it all worked out :slight_smile:
