I am able to set up a simulation in CHT v1 with the following:
- Customised Water Properties
- Customised Aluminium Properties
- Mass Flow Inlet
- Zero gauge pressure Outlet
- Thin Layer Resistance (simulating a thermal interface material)
- Absolute Power applied to a solid
This meshes fine and the simulation runs fine although I previously posted here (Interface Type Not Available - #4 by dcrowley) that contact modelling is not available in CHT V2.
Now, when I rebuild the simulation again in V1, I get the error on meshing “the physics cannot be taken into account as the simulation setup is not valid.”
Is there a fundamental difference between v1 and v2 meshing that causes this issue?
I want to simulate fluid flow through a heat exchanger - and neither CHT v1 or v2 seem to be able to create this modelling accurately.
Please advise.
