Hi all,
a general question: is it possible to extract the full OpenFOAM code of a simulation I did in SimScale? If yes, how?
Thanks in advance,
An-Sofie
Hi all,
Thanks in advance,
An-Sofie
Hi An-Sofie (@achristiaens)!
It is indeed possible to get the code! You simply have to go to the run(s) you would like to have a look at and download the results. Once extracted you can have a look at the folder structures like system, constant, and the 0 folder with the boundary conditions.
Let me know if it works!
In addition to what @jousefm has said, there might be some manual changes you need to do, depending on your OpenFOAM version, its a case of re-running observing the errors and warnings and making the changes. For example, in the latest openFoam the name of the turbulence properties file changed between SimScale version and v5.
Good luck!
Darren
Forgot to mention that Darren - thanks for clarifying!
I am trying to run Simscale simulation file in OpenFOAM however I am getting error as “cannot find file turbulenceProperties”.
What is the workaround to replace this file?
Waiting for your reply.
I am using OF4Win 19.10 version
Sachin
You can compare the files used in 2.3.x with the files used since v3. Basically, you have to replace
RASProperties
RASModel kOmegaSST;
turbulence on;
printCoeffs on;
with
simulationType RAS;
RAS
RASModel kOmegaSST;
turbulence on;
printCoeffs on;
Yes. Its implemented and running it now. Also change of the file name to turbulenceProperties.
Is it possible to do so with just the community plan or do I need a paid one?Thanks in advance
