One fluid-fluid interface erros
I’m am fairly new to simscale and I am trying to run a Conjugate heat transfer V2 simulation on a building and how it reacts to the solar/radiation effects. But I have been receiving an error saying
" The following simulation run(s) failed:
  • Run 1
    • Your simulation has at least one fluid-fluid interface. This type of interfaces are not allowed if radiation or solar load are enabled".
      I’m not really sure what this error means as there is not much detail.
Hi @saulf_f, thanks for posting on the forum and welcome to the SimScale Community :handshake:
Taking a look at your simulation, I see that you haven’t created a flow region and set the walls of your domain as being composed of air. In order to observe the behavior of air in your domain, you need to create a flow region as described here:
I think you’d also benefit from running some tutorials before getting to your simulation. I think these two might be particularly interesting:
Does that help?
