I want to make a simple multiphase simulation, where I have to chambers with air connected by a pipe with water in it. I assign air to the two top solids and water to the bottom solid. Simscale gives me an error saying I need to assign exactly two materials to the multiphase domain.
I would like to carry out a very simple simulation where I have different pressures in the two chambers filled with air. The chambers are connected by another chamber filled with water.
I want to see the height of the water change due to the pressures acting on the water surface as seen in the below picture.
I dont understand how to model and mesh this. So far I made the U-shaped body in the project and split it into 3 parts; 2 parts air and 1 part water, is this the wrong approach?
Hi again, thank you very much for your thorough answer. I still have a of question I hope you could clarify:
You assigned the materials air and water to every part of the solid. I guess that makes sense because every part of the solid can potentially contain water or air? When I originally assigned air to the two top smaller solids and water to the bottom solid, I basically said that air could never leave the small solids and likewise for water?
Yes, that is right, just bear in mind that in a multiphase simulation, only one part domain is allowed, thus you need to assign both materials to the one part.
