Multiphase Bubble Nucleation
Trying to simulate an experiment whereby I can calculate the mass fraction of air that is released from a water flow induced into a vortex. I am trying to set the simulation up using multiphase but I’ll be honest I have no idea what I’m doing.
I have all the correct temperature, Mass flow, inlet pressure etc but I just can’t get a good result to show.
Hey KrishJones,
Please note that you cannot simulate phase change in SimScale as of yet. A multiphase simulation is used to simulate the time-dependent behavior of two incompressible, isothermal, immiscible fluid mixtures using the VOF (Volume of Fluid) method.
You can also refer to this tutorial to take a look at the capabilities of the multiphase simulation.
If you need more support with the project, do provide us with more details about the project or the results and also feel free to add a link to your project here and share it with support.
Satvik
Hi Satvik,
Ah okay, good to know I’m way up the wrong tree :sweat_smile:
Thank you for getting back to me so quickly :slight_smile:
