I’m trying to analyse winds on a site in order to determine the way we could create passive cooling in our building. But i get a meshing error telling me “an error occured” without any more information. My geometry doesn’t seem to have any problem but i might be missing something as i’m new to Simscale, I also tried modifying some of the meshing setting but it still doesn’t work out. Can somebody help me find a solution ?
Thanks in advance !
The project, simulation and geometry can be found here: CHU Poitiers | SimScale Workbench
here’s the meshing log, it doesn’t seem to shows any mistakes:
SimScale incorporates Simulation Modeling Suite™ software by Simmetrix Inc. © 1997-2024. All Rights Reserved.
Model import took 1.088386847s.
Maximum precision of model and its entities: 0.0004881006724017567 m.
Absolute small feature tolerance: 0.3 m.
Gap refinement size is reaching lower cell size cap for 1 regions. Consider lowering model tolerance if resulting mesh fineness is too coarse.
Determined sizing is reaching lower cell size cap for 53 faces. Consider lowering model tolerance if resulting mesh fineness is too coarse.
Number of faces after 5m0.000253028s: 5166
Surface meshing took 8m41.032500977s.
Number of cells after 13m1.591364606s: 1238895
Number of cells after 17m22.120758124s: 12511336
The mesh may be finer than desired. Please check the model and the mesh settings
Number of cells after 21m42.627273773s: 17051086
Number of cells after 26m3.175976579s: 16978087
Number of cells after 30m23.703508007s: 17019828
Number of cells after 34m44.135503362s: 17042824
Number of cells after 39m4.737003456s: 17049209
Number of cells after 43m25.25950568s: 17054792
Number of cells after 47m45.775502505s: 17057854
Number of cells after 52m6.270050902s: 17060377
Meshing took 54m12.237630703s. Starting mesh export.
