I am simulating a formula student car. After generating mesh i cannot inspect mesh quality in the mesh quality tap, for some reason it remains white whatever the parameter i want to inspect
as shown in the figure, aspect ratio max value is 1.504e+5 but still no red regions indicating where’s the bad cells. the same for non-orthogonal quality
Hi @aerodynamics_c, thanks for posting on the forum and welcome to the SimScale Community
As it seems you have deleted the faulty mesh, I can only give you general advice on how to improve it’s quality. Looking at your model, I see details such as this one near the car’s tire:
Thanks for your fast reply, actually for the gap between tire and ground, i doubted it would cause a problem too, but i was following the tutorial for FS car simulation in the following link and in creating fluid domain section, it is stated clearly for lower wall" As much as necessary in the negative z-direction, so that the ground can be tangent to the wheels"
i tried as much as possible but it resulted in this small gap. is it a solution to : create like rectangular solid beneath the wheel and touching the lower wall?
