I am trying to run CFD on a model of F1 2022 spec car. The mesh does not generate specifying the issue as just “An error occurred”.
Upon going through the meshing log, I find all faces to be legal i.e. not error in orthogonality, skewness etc. But during final balancing, there seems to be an error occurrence saying “one process returned non-zero exit code”.
Kindly help, as I am not able to diagnose any issues. I have attached screenshots and my project link. The issue lies in simulation named “Full Model 3”
Log in to your SimScale account. SimScale makes high-fidelity engineering simulation technically and economically accessible. At any scale. In the cloud.
I’ve ran some tests on your model and it seems like there are some issues in CAD impeding an external flow volume from being created. If I try to create a flow region enclosing the full model, I get this error:
I think your CAD would benefit from some cleanups as the simulation will probably diverge due to meshing issues which will potentially be caused by small faces present in it. For example these ones:
As a final note, I think selecting the material point farther away from the CAD would make the mesh be more easily generated, since it will be where it will start to be produced (I’m not sure how much this would affect the success).
I wouldn’t, however, advise you to run a simulation with a wraped body since it’s surface will be very rough and the analysis will likely diverge due to meshing issues.
You can find the project I did this here: SimScale Login
I have done a few simulations using the hex dominant mesh which have provided me with pretty good and wanting results also as we had aimed for higher accuracy results on an FSAE Racecar.
Would gladly consider cleaning up my CAD geometry as a first step.
