Mesh export
Can we export SimScale mesh in the format of .msh file ?
Hi @Vinaykumar!
We already had a discussion about that in the past, maybe this helps you a bit: Exporting SimScale Mesh To Ansys Fluent. Let me know if that helps!
Hi @jousefm
Thank you for the answer and sorry for the late reply .
The discussion was very helpful and it worked when I import the simscale mesh from OpenFoam to Fluent.
When I have only one fluid domain or single body it worked. But when I have different bodies for a simulation type Conjugate Heat Transfer (CHT), it generated different polymesh files for each bodies and when I run in OpenFoam it displayed as FATAL error. Can you suggest any solution ?
