So while the mesh completed the simulation gave me an error:
“The job execution was aborted, possibly due to a numerical instability. Review the log to identify reasons: nonphysically large field values, extremely small time step size, etc. Modifying numerical settings and time step size could resolve the issue.”
Here is the log
Create time
Create mesh for time = 0
Reading field p
Reading field U
Reading/calculating face flux field phi
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
alphaK1 0.85;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.856;
gamma1 0.555555555556;
gamma2 0.44;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
b1 1;
c1 10;
F3 false;
Creating finite volume options from “system/fvOptions”
SIMPLE: convergence criteria
field k tolerance 1e-05
field U tolerance 1e-05
field “p.*” tolerance 1e-05
field omega tolerance 1e-05
Starting time loop
faceSource faceSource201:
total faces = 3348
total area = 0.002164806518
specific scale factors =
p 997.33;
p_rgh 997.33;
→ FOAM Warning :
From function writeOldTimesOnSignalFunctionObject::writeOldTimesOnSignalFunctionObject
in file misc/writeOldTimesOnSignal/writeOldTimesOnSignal.C at line 84
‘writeCurrent’ was set. This may lead to uncaught segmentation faults
→ FOAM Warning :
in file misc/writeOldTimesOnSignal/writeOldTimesOnSignal.C at line 105
sigTERM unset. Setting it to true so that signal is propagated to other processors
If this is undesired explicitly set ‘sigTERM false;’ in “system/controlDict.functions.sigHandler”
[0] Set SIGFPE(8) signal handler
To switch this off set ‘sigFPE false;’
[0] Set SIGSEGV(11) signal handler
To switch this off set ‘sigSEGV false;’
To catch Ctrl-C set ‘sigINT true;’
[0] Set SIGTERM(15) signal handler
[0] Set SIGQUIT(3) signal handler
To catch the USR1-signal set ‘sigUSR1 true;’
To catch the USR2-signal set ‘sigUSR2 true;’
4 signal handlers installed
[1] Set SIGFPE(8) signal handler
[1] Set SIGSEGV(11) signal handler
[1] Set SIGTERM(15) signal handler
[1] Set SIGQUIT(3) signal handler
[3] Set SIGFPE(8) signal handler
[3] Set SIGSEGV(11) signal handler
[3] Set SIGTERM(15) signal handler
[3] Set SIGQUIT(3) signal handler
[2] Set SIGFPE(8) signal handler
[2] Set SIGSEGV(11) signal handler
[2] Set SIGTERM(15) signal handler
[2] Set SIGQUIT(3) signal handler
faceSource faceSource200:
total faces = 3292
total area = 0.00216410415835
p 997.33;
p_rgh 997.33;
Time = 1
[1] Signal 8 encountered
[1] Going to reraise SIGTERM after writting
[1] Resetting old handlers (just in case)
[1] Unset SIGFPE(8) signal handler
[1] Unset SIGSEGV(11) signal handler
[1] Unset SIGQUIT(3) signal handler
[1] Writing old times:
[1] 1 times to write
[1] Writing current time 1
[1] Printstack:
[1]
[1] #0 Foam::error::printStack(Foam::Ostream&) at ??:?
[1] #1 Foam::writeOldTimesOnSignalFunctionObject::sigHandler(int) at ??:?
[1] #2 in "
[1] #3 in "
[1] #4 pow in "
[1] #5 Foam::pow(Foam::Field&, Foam::UList const&, Foam::UList const&) at ??:?
[1] #6 Foam::pow(Foam::UList const&, Foam::UList const&) at ??:?
[1] #7 parserPatch::PatchValueExpressionParser::parse() at ??:?
[1] #8 Foam::PatchValueExpressionDriver::parseInternal(int) at ??:?
[1] #9 Foam::CommonValueExpressionDriver::parse(Foam::exprString const&, Foam::word const&) at ??:?
[1] #10 Foam::tmp > > Foam::CommonValueExpressionDriver::evaluate >(Foam::exprString const&, bool) at ??:?
[1] #11 Foam::groovyBCFvPatchField >::updateCoeffs() at ??:?
[1] #12 Foam::GeometricField, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::updateCoeffs() at ??:?
[1] #13 Foam::fvMatrix >::fvMatrix(Foam::GeometricField, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) at ??:?
[1] #14
[1] at ??:?
[1] #15
[1] at ??:?
[1] #16 __libc_start_main in "
[1] #17
[1]
[1] at ??:?
[1]
[1] Raising SIGTERM so that other processes will dump too
[1] Signal 15 encountered
[1] Unset SIGTERM(15) signal handler
[1] Other handler dumped already. Exiting
[1] Sleeping 60 before reraising SIGTERM to allow other processes to write
[1] Reraising original signal
[2] Signal 15 encountered
[2] Resetting old handlers (just in case)
[2] Unset SIGFPE(8) signal handler
[2] Unset SIGSEGV(11) signal handler
[2] Unset SIGTERM(15) signal handler
[2] Unset SIGQUIT(3) signal handler
[2] Writing old times:
[2] 1 times to write
[2] Writing current time 1
[2] Reraising original signal
[3] Signal 15 encountered
[3] Resetting old handlers (just in case)
[3] Unset SIGFPE(8) signal handler
[3] Unset SIGSEGV(11) signal handler
[3] Unset SIGTERM(15) signal handler
[3] Unset SIGQUIT(3) signal handler
[3] Writing old times:
[3] 1 times to write
[3] Writing current time 1
[3] Reraising original signal
[0] Signal 15 encountered
[0] Resetting old handlers (just in case)
[0] Unset SIGFPE(8) signal handler
[0] Unset SIGSEGV(11) signal handler
[0] Unset SIGTERM(15) signal handler
[0] Unset SIGQUIT(3) signal handler
[0] Writing old times:
[0] 1 times to write
[0] Writing current time 1
→ FOAM Warning :
From function writeOldTimesOnSignalFunctionObject::sigHandler(int sig)
in file misc/writeOldTimesOnSignal/writeOldTimesOnSignal.C at line 162
This action may end in a segmentation fault
Set ‘writeCurrent false;’ to avoid this
[0] Reraising original signalmpirun noticed that process rank 1 with on node 8a5ab995cd3e exited on signal 15 (Terminated).
