I’m new to SimScale and have followed along with some of the existing thermal comfort tutorials.
I am having porblems creating and Internal Flow Volume for my own model, with an error of:
Invalid Seed face
The Seed face [face 40733 @ Solid 116]sessionId=eb2b8f44-c067-41f0-83d8-c17c7916ae1d#) is adjacent to another body and therefore could not be used to generate the flow volume. Please select a Seed face which is facing an empty space (is adjacent to a void region).
Thanks for the project link. I see that your geometry is almost ready, but you still have some sheet faces there, which doesn’t allow you to proceed with simulation. Please fix those ones solidifying it in your native CAD software and then import it again to SimScale Workbench.
I have made the necessary changes to create the Internal Flow Volume and have input all of my boundary conditions, when trying to run the simulation I am receiving the below error:
A setup with at least 60 regions is being used in a single-region analysis type. Please ensure that only one fluid region exists and that all other bodies are assigned to an advanced concept. If you have already meshed your geometry, ensure that all the meshing regions except one are cell zones.
I do not under how there can be 60 regions when only a single flow volume was created?
Thank you for the amazing support, I have managed to sucessfully run the simulation.
I am getting one anomalous reading from one of the velocity outlet boundary condition (Fresh Air Outlet (Extract)). This was set to 0.072m3/s for a 150mm duct and results are showing velocity vectors of up to 30m/s which does not seem correct:
