Hello
i have openfoam mesh in files like on screen shot
I put all of those files in this directory along with file “transportproperties” to zip and uploaded. Everything seems fine only my mesh is not in project
Can you help me out please ?
Hello
Hi @Novak_Ondrej!
Have you done the following steps?
Zip the entire “constant” folder
Upload it using “Upload mesh” option with type as “OpenFOAM” selected.
Great ! it worked very well.
but i m getting this error
domain is only interior mesh around part of wing … what should i do with rest ?
As it seems, simscale ready 3 zones … i need only the first one ( or so i think ) … so please, how can i remove it ?
Hi @Novak_Ondrej!
Just for understanding, why did you not mesh it on SimScale directly?
Hello
my mesh uploaded from open foam (exported from ICEM) is simple single region mesh
however when i upload to simscale it creates 3 regions to whcih i have to assign BC and that makes simulation fail
what can be done about that please ?
I tryed. simulation ran for few hours than failed but its no good for me anyway. Best option for me is to mesh it in ansys where i have so much more options for meshing ( i have to use tetrahedral mesh).
Only problem is that i get imported 3 zones … i tryed very simple geometry like a box and it did the same so there must be an issue with import
I have used ICEM before but not coupling it with SimScale so far so I would have to dig a bit deeper into this. Also I see that the mesh consists of polyhedrals, I would have to check if the solver has issues with these kinds of elements. Will let you know more about it as soon as possible.
Sorted ! it seems that “Fluent3DmeshtoFoam” creates 3 zones … but “fluentmeshtofoam” creates only one which is perfectly fine for simscale … already tested and works fine so thanks for help
Just was looking at fluentmeshtofoam Please let me know if the simulation runs smoothly!
Well residuals in beginning oscilate and than they settle down and converge nicely
Yay!!
Let us see how the results look like - very curious about that!
