IBM simulation of a brazed plate heat exchanger
Hello everyone!
I’m doing a IBM simultion of a brazed plate heat exchanger. I have already done several others with exactly the same geometry, numerics and Boundary Conditions and they all converged. However, with this one, I am receveing this error: “The global continuity error cannot be removed by adjusting the outflow. Please check boundary conditions for pressure and velocity. Consider using a pressure or velocity outlet boundary condition to avoid this problem.” Basically the only thing that is changed from other simulation is the inlet temperature BC from 41°C to 57°C.
The simulation with problem:
Similar Simulation (watch the seocond IBM sim):
Thank you.
Hi @marcosimscal3,
Thanks for posting on the forum and welcome to the SimScale Community :handshake:
I’m checking out your simulation and will make sure to get back here later with my findings.
Hi @marcosimscal3,
I think there’s one extra change from the successful/unsuccessful runs.
On the successful run, these faces are unselected:
Whereas on the unsuccessful they are selected:
Maybe trying to change this and rerunning the simulation is a good first step. I’ll also ask you to try and reduce the amount of core hours you’ve been using on your simulations - this will lead to less computing resources being spent and the simulations being run faster. One thing that might be helpful is setting the compressible option to off:
And also reducing the number of iterations by stablishing an acceptable tolerance value:
Thanks Igor. This solved my problem,
Regards
