I am currently trying to get into SimScale, starting with the generation of a mesh for CFD,external flows.
I would like to insert more than one geoemtry to generate my final mesh: I need the aerodynamic model, wind tunnel, cellZones, refinementBoxes. But I can’t find the way to do it. If I upload a new geometry, it seems like it’s going to create 2 separate meshes.
Furthermore, is it possible to assign different meshing features (refinement levels, number of layers) for each PID on the model??
wind tunnel meshing, generation of cell zones (I guess for a rotating region?) and using boxes for local refinement is supported in the “Hex-dominant parametric” mesh operation. What’s not supported as of now is the combination of multiple STLs within SimScale. But the easiest way to achieve that is to merge your STLs before uploading them. If you’re using linux, simply hit
yes, you can assign different local refinement types (surface, region, feature, layers) and control all their properties locally per face. Not quite sure though what you mean with PID - patch ID?
Just a short question: I generated the mesh, and the process is finished (I can see the log file). However the job is still running/computing, and I cannot visualize the mesh (it’s already 30 min after). Is there some transfer job after the runs?
yes, there is some post-processing with the mesh happening after the actual mesh generation is done (visualization, quality analysis, persistence etc.) - that can take some time if the mesh is very large but 30 min sounds very long. If you can see the log, how many cells were generated?
The run is now ended.
But looking to results, I am not so happy. It seems that snappy and layer were not processed.
Yes, you can look for my name. it’s a small project for an application process by SimScale.
I think you already deleted the old mesh, right? For “debugging” purposes I typically simply duplicate the setup, tweak and run again - that way you can review old meshes.
I have the same problem with the geometry and i do not know how to upload a model made of different STL files. I do not have linux so is there any other way to make it?
Hii!
Thanks for the video it was really helpful but I still have some small problems. I do not understand how he merges the files. I have all the .stl files of my model but i do not understand the way he merges them into a one single file. In the video it is shown in the minute 1:41:10 if i am correct and that is the way to merge the files.
What text editor can I use to do it because the one i have doesn’t work
Hi
Thank you for your quick answers. I have done exactly as the tutorial and when I tried to upload it gave me an error. This is the project:
Also when I open any .stl file with my cad software that I export in ASCII format the piece is not correct and has nothing to do with the real piece. I don’t know why this can be caused.
I also tried to do it with the script of the tutorial and had exactly the same result.
Any idea where the problem can be?
Thanks for the help, sorry for the trouble.
Enrique
