In the documentation it says: “You can choose bigger machine for the analysis. By choosing it, you can provide the solver with more memory under which the analysis can be easily solved. For example, for a bigger mesh i.e. more than a million 3D elements, assigning analysis to 1,2 or probably 4 cores under Simulation Control will lead to this error. Try to assign at least 8, 16 or 32 cores.” Thus mesh size plays a big role and needs to be taken into account for the simulation.
Please share your project with us to have a closer look at this issue and make sure it is set to public.
You said that “You can choose bigger machine for the analysis. By choosing it, you can provide the solver with more memory under which the analysis can be easily solve"
You mean to say that should I use bigger RAM holder machine ?
Does the simulation run at the machine which I use here for simulation or at your(simscale cloud) ?
