I’m working on a CFD simulation of a centrifugal water pump and I keep getting this error message on my simulation runs that are failing: Gauge pressure field started diverging. Please check the mesh quality near the reported location and try refining the mesh. If the problem occurred near a boundary, please check the boundary conditions.
I’ve tried solving the problem multiple times by looking at other examples in the forum but keep getting the same error, is there anything that I am blatantly doing wrong that is making this happen every time?
It seems you’ve defined 0 Gauge Pressure for both the inlet and the outlet, which will make it so there is no flow on the turbine. Have you had a chance to take a look at this tutorial:
