I got following messege when meshing is done: “Mesh quality check failed. The mesh is not OK.” This messege comes right before “Mesh import started”.
I checked all parameters and found one little mistake in: mesh refinements - feature - Feature refinement levels. There I got 0 instead of 0.001 . I changed it and let the 0 deg and the 6 deg mesh run again. But I got the same problem with mesh quality …
Can this warning be ignored, or will htere be Problems while simulating?
Does someone know how to fix it?
Project is publik so feel free to have a look
