It looks to me that due to input data precision errors, I am no longer able to enter a unit vector for 3 degrees (and likely almost any other discrete angular vector value) in the Forces and Moment Coefficient Result Item without being presented with an Error message that prevents simulation runs when my rounded unit vector value is virtually 1 like the example I show below.
The number of significant digits that I am allowed to enter for a 3 degree unit vector lx is 5.234e-2 and lz is 9.986e-1 which comes out to a unitized value of 0.999970717371264, which apparently isn’t close enough to 1 for the error generating code which SimScale currently uses to test if I have input unit vectors properly
If I have this issue properly analyzed, can the error checking code be adjusted somehow to fix this, say when the unit vector is within 0.001 of actually being 1 then the error will not be generated.
I am stuck with not being able to run any simulations until I get some help on this.
Dale
