Very new to both CAD and SimScale. I’m trying to model airflow through a velocity stack. I can’t manage to generate an internal flow volume. I thought I had selected the two boundary faces appropriately. I’ve checked for gaps, and there don’t seem to be any in my model. Any help you can provide would be very much appreciated!
This part (image below) of your geometry seems to be not connected properly. This in turn, affects the parabolically tapered surface (hidden in image) connected to this.
This would be easier for you to resolve in your CAD tool and reimport into SimScale.
This message appears because you have more than one body in your simulation setup. If you’re trying to run an incompressible analysis, you need to have only one body as a flow region (which is the portion of your system where the fluid will be).
For reference, take a look at this portion of one of our basic tutorials:
