I am trying to simulate our front wing but I am getting an error message while meshing as:
“The meshing algorithm failed with a floating-point exception”
I have read posts regarding this but mostly all of them refer to this error faced during simulation whilst I am facing this error in meshing. My initial conditions are fine with pressure being 0 and k and w being non-zero quantities.
As mentioned earlier, I have read this post and double-checked my initial conditions also. The post suggests changes that I guess would affect the simulation and not meshing. I am getting the problem in meshing.
It is definitely not normal for a mesh to have this huge quantity of poor cells, which indicates issues somewhere else in the setup. One common issue that I see is when the bounding box resolution is poorly set.
In short, the issue here is with these values, that seem to have been copied from a different mesh (which had a different orientation).
Thanks for showing this mistake. It was obviously an error from my side. I have corrected the settings and started the meshing again. Will let you know if this happens again,
